Adding and removing serial numbers
Command |
Path |
Vectorworks Preferences |
Tools > Options |
During installation you are required to enter the serial number provided with the Vectorworks product(s). You may also need to update a serial number later to enable more products or to switch from a trial version to a full version.
To add a serial number:
Select the command.
The Vectorworks Preferences dialog box opens.
Click Serial Number from the Session pane.
The Serial Number dialog box opens.
Click Add.
The Add New Serial Number dialog box opens.
Enter the serial number exactly as it appears on the label. The serial number is case sensitive. The letters O and I are not used in serial numbers; enter the number 0 or 1 instead.
Click Add.
The list of Enabled Products in the Serial Number dialog box displays all products enabled by this serial number. For security, serial numbers that begin with the letter E are partially hidden wherever they display in Vectorworks.
Only one serial number can be applied at a time. When the serial number is set, click Done.
To remove a serial number:
Click Serial Number from the Session pane of Vectorworks preferences.
Select the serial number to remove, and then click Remove.
Click Done.
